Seatbelts retracting slowly
did mine today after i got fed up of mine getting stuck in the door
now there 10 times better
  • 1 year later...
  • Replies 30
  • Views 25k
Does this work with mk4 ones as well? Always been a bit cautious about fiddling with them because they've got the explosive charges (?) in them to make them tighten in an accident.
so why the hell didnt mine tighten when i smashed it up? that car was fucked all round :disgust:
There is a heavy ball which sits in a cup type arrangement. When the ball comes out of the cup it locks the seatbelt into position, like in an accident and keeps it tensioned. This is also what happens sometimes when you pull a seatbelt and it gets stuck whilst you're putting it on, it's because the ball has become unseated. Newer cars also use sensors linked to the airbag system which use a pneumatic system to tension the seatbelt and keep the occupant seated. It is self adjusting to the user in the seatand gets tighter the more the occupant moves. These are called inertia belts. This is what some people refer to as the explosive system, but it only works on the pre-tensionisers, the gas expands so fast that it is effictively 'exploding'.
  • 5 months later...
pointless thread
and you are?
You bought a thread up from 6months ago to say it was pointless? - That's pointless.
  • 4 years later...
Some people........ I just hoovered mine and a massive improvment. Thanks.
