German plates
Will they fail the MOT on the basis of my plates? :paranoid:
  • Views 1.7k
yes I'm pretty sure yhey will just put you old 1s on for it
Just found this in the MOT handbook it looks I should be fine but I shall put the originals in anyway
Reason for rejection
Registration Plates
Unregistered vehicles
Unregistered vehicles need not be fitted with registration plates.
Style of letters/figures
Letters/figures must be of equal width along their entire length.
Letters or figures of a particular style, eg 'computer' or 'sloped' are not to be regarded a reason for rejection unless they are likely to be misread,
Note: a three-wheeled vehicle, which has a motorcycle derived front end, does not require a front number plate.
1. Check that there is a registration plate both at the front and the rear of the vehicle, and check each one for security and condition.
2. Refer to page 6 and check visually that the letters and figures are correctly formed, spaced, and are not obviously likely to be misread due to, for example, badly positioned or uncovered retaining bolts etc (see information column
Style of letters/figures).
1. A registration plate:
a. missing or incorrect
b. so insecure that it is likely to fall off
c. letter or figure missing or incomplete
d. faded, dirty, deteriorated or obscured, (for example by a towbar so that it is likely to be misread or is not easily legible by a person standing approximately 20 metres to the front/rear of the vehicle)
2. A registration plate with:
a. letters and figures obviously incorrectly spaced
b. letter or figure not correctly formed or likely to be misread
c. a letter or figure which is obviously not of equal width along its entire length
d. any feature on a number plate that has the effect of changing the appearance or legibility of any of the characters, so that the true identity of the vehicle is less easily identified.
They should fail you for it. But it doesn't mean they definately will. Depends what kind of day they are having and how much they like you I guess.
can i put a question in as well???
what is the rule on the letter grouping? can you change the grouping as long as the spacing is correct? i seem to see a lot of letter groups changed, specially withing the in and around london... like B3NNO or A1 5TAG...
does anyone know?
does anyone know?
No, that's illegal and there was something in the news recently about the police clamping down on it. The rule is that the spacing between the two groups of characters must be double the spacing between the individual characters, e.g.
ABC 123Y
B123 ABC
AB55 XYZ
BAZ 1234
etc etc.......
ABC 123Y
B123 ABC
AB55 XYZ
BAZ 1234
etc etc.......
okay, see if i get this right... as long as you have the correct spacing between groups, you can then regroup them? for example...
ABC12 3Y
B12 3ABC
AB5 5XYZ
BAZ1 234
is that right 6Newan?
ABC 123Y
B123 ABC
AB55 XYZ
BAZ 1234
etc etc.......
ABC12 3Y
B12 3ABC
AB5 5XYZ
BAZ1 234
Noooooooooooooooooooooooooo.
You cannot regroup characters - they have to be grouped according to their original configuration.
e.g. Spaniel's registration on his avatar reads G40 PY. However, he has re-grouped G4 OPY, which is illegal. (No offence, Dan) Same with the examples you gave: B3NNO should be B3 NNO, and A1 5TAG should be A15 TAG. I believe the cops are going to be dishing out POINTS for incorrect spacings from now on.....
