MOT Requirements
Hey there,
Just wondering if anyone out there could tell me if I could pass the MOT test with a few things 'wrong' with my car...
- Central locking pump has failed, need to get a new one
- Door lock rod has broken on the passenger side. Can't gain access with a key, need to open it from inside
- LH taillight flickers on and off when it should be on, can't figure out why it is!
Thanks in advance! :thumbsup:
Alex
should be fine, or how would cars without central locking get through an MOT?
Leave it unlocked when you go to be sure but i never checked when i worked as an assistant
Fail
hope this helps mate :thumbsup:
Edited by deex
Hey thanks for the quick reply
Any ideas on why the rear tail light would flicker? I've had a look at the bulb and tried swapping it with the other side, but it still flickers
i would take a look at the connections mate, see if any wires are coming loose? also check the earths maybe? I'm no expert though
possibly corroded connectors? Pull the plug out of the light cluster and clean the connectors on the light cluster with a piece of sandpaper so they are shiny.
