BAD starting
HI friends, my 8 valve 1.4 starts 1st time from cold but if i drive a mile or two stop it then try to restart it, i have to crank the motor a lot and feed the throttle in to get it to start again! any ideas where to look, thahks jules :paranoid:
  • Views 1.4k
maybe try a temp sender first matey :-)
Get a diagnostic report mate, saves u buying stuff you dont need.
Hiya pal. I'm having the same problem, have you found out what the problem was?
Edited by miniwogger
dont want to sound dumb but where is the temp sender located on the polo? tried to get one today there is about 7 different ones
