Steamy indicator!
Got my angel eyes on a couple of weeks ago and one of the indicators seem to be steaming up. I'm guessing there is a crack or abit of water init somewhere.
Just wondering how i solve this. I thought about taking the plastic off the indicator and then re-sealing it.
Any advice would be great..thanks
  • Replies 13
  • Views 2.4k
mine did it to.. 2 weeks after fitting the matching lenses.. just fks cheap build quality mate... just wait tilll its sunny and it will dry out :)
Yes thats a nice idea mate, but its really bugging me and i want to sort it out so it doesnt happen again.
Anyone else got any ideas?
drill a tiny hole at the bottom of the indicator cluster, should let air circulate in an out properly
thats a really good idea. drill a hole on the bottom so water can drain out.
Ohh ryte, if it works i could give it a go. Thanks
Has anyone else got any ideas? Would drilling a small hole in the bottom of the indicator really work?
You want to seal it,ideally. The hole trick should work to some extent by preventing moisture getting trapped in there - but it wont prevent moisture getting in there in the first place,and some steaming is still likely.
If it was just the standard set, i would have recommended baking it for 10 mins on Gas mark 8 to melt the current seal, washing it out and drying it fully, and then re-sealing it all properly.
However i'd be wary with some fancy pants kit...
Guess thats why you shouldnt buy angel eyes, unless you have an E39 M5.
the holes at the bottom of the cluster an liquid water doesn't really travel upwards through the hole
water vapours unlikely to move in through the hole because of the pressure differences between the outside an inside of the cluster, small volume inside the cluster, higher pressure when moisture tries to enter, doesnt let it get in :D...i think :? lol
open them up and tape some silica gel inside them. The stuff you get in shoe box's and stuff to absord the moisture. Usually in a white square bag.
Google explains it as this...
Silica gel is a granular, porous form of silica made synthetically from sodium silicate. Despite the name, silica gel is a solid. It is usually distributed in the form of beads, which are packaged in a semi-permeable packet.
But u gota get the bag in the lights somehow.
Thanks guys..
Think the best thing to do is to re-seal it. I'm going to give it a go in the next couple of days :thumbsup:
Am i correct in thinking that if you just put the lights in the sun the moisture will dry out? Has anybody actually over came this problem lol
Get a hair dryer to it and blow hot air at it from different angles to dry it out then seal up the hole/crack if there is one.
luke
