beetle seats?
I'm currently pur-chasing a set of beetle seats do i need to do alot of modding to the subframes or should i just try n put some polo ones on it?
Here they are
  • Views 1.7k
Popular Days
Found out by trial and error, and its pretty simple.
Using the beetle sub frame, all you need to do is cut off bout 60mm and re-drill the 8mm hole (mine had a suport brace and needed cutting and re-welding). You then need a 2 pieces of steel to fit in the runners and a 2 bolts, bout 60/70mm, and srew them in till their tight. The front can just be held in place with original spring held bolt.
it only took me 40mins. Thier abit tight (great excuse for no rears) but look great.
