plastic welding
thinking of having a bash at it
can any one give me any info on how to go about doing it
cheers neale
  • Replies 15
  • Views 2.7k
depends what your plastic welding ?
i weld mesh into holes / crack then build with plastic over the top
don't wast your money mate go and get you self a soldering iron they last for ever and wont run out :thumbsup:
that isnt plastic welding though, that is just getting two bits of plastic hot and mauling them together.
plastic welding done properly [or extrusion plastic welding] is done with a heating tool and you add plastic with a plastic welding rod.
the proper kit is pretty expensive.
yeah you won't be able to do it with a soldering iron
the proper kit is easy to use though :)
I've seen grry's work before and its spotless. Bumper on his mk2 goof looks top!
where do i get the plastic rods to use?
I've seen plastic welding kits (Sealey) in the back of demon thieves for £100 plus VAT i think you can also get packs of rods too
cheers
blow torch and a flat head screwdriver
What kinda plastic are you trying to weld? If it is ABS, you can use lego bricks to "weld" Or just make a paste using acetone and black lego then create a shape using masking tape and fill. Remove the take and tidy up and you are done
lol how funny
duno what plastic tbh what ever mk 4 bumpers are
and whatever mk2 ibiza bumpers are :D
they will probably be the same chris
bump any one know?
hey neal man hows it going
i used to plstic weld for a few months basically u need a sealey gun (a glorified ht air gun) whihc comes with a tacking nozzle and a welding nozzle. u use the flat tacking nozzle to tack the piece(s) together then change the tip over to a welding end and feed a length of plastic rod either ABS,polypropolene,polycarbonate or whatever it is past the end of the gun and into said recess/hole/crack.
its a fairly easy process but yeah the guns are about £180 and rod is fairly pricey as u usually have to buy a large roll of it say 100meters
