Adjusting Idle on a mk4 1.4
I am having a problem with the idle on my mk4, the idle was ok until my head gasket went i have replaced the head gasket and now it idles at 20 and keeps going up and down either above or below 20. Is there any way of adjusting this?
Adam.
  • Views 2.3k
U cannot adjust the idle as its electronicly controlled by the ECU.
But people have adjusted the accelerator cable to bring it down or up. U can try that.
If your idling at 2k revs and erraticly...Click HERE
Thanks gavin
you need sombody with vag-com to reset the adaptive settings for the throttle body i expect...
disconnect the battery for a few hours
