6n2 rear lights on a 6n??
iv fitted them and wired them all in and everything is fine apart from they stick out slightly at the bottom, iv tryed shaving abit of the plastic off around the edge but they still wnt sit in further because of the screws only go so far in to the hole... any suggestions??? thanks
  • Views 1.5k
have you followed this guide VERY closely
clicky 4 guide
Sounds like you havnt drilled the holes in the actual shell of the car you need to do this to allow them to sit flush aswell as cutting a bit off and maybe sanding them a bit.
cheers for that guys, all sorted and they look gr8.....cheers
  • 4 months later...
i got the mk5 lights on my mk4 and trust me don't be cutting any off your lights or drilling bigger holes, weld a plate sitting flush with the lights,they stick out because the mk5 is slightly more curved than the mk4 so they stick out where its suppose to sit flush. i'm welding a plate there on my car but i have a mk5 tailgate on it to bring it flust to.
Edited by mk4mike1.4
