Removing a gearbox.
How easy/hard is it to remove a gearbox from a mk4 polo 1.4 CL, and then fit a new one after? Cheers, Chris
  • Views 1.2k
Easier than the earlier cars - sounds like you need a Haynes manual and,I'm thinking,one full day. But make sure you've got the following day free,in case you dont manage it. You'll need a suitable tool to centre the clutch,asuming you're changing it,and an 8mm splined bit for the driveshafts - everything else is pretty standard stuff.
