how to remove the casing froma mk5 wing mirror?
as tite says really i need to get off the casing from a mk5 mirror i have to get it sparayed and wanted to remove it instead of having to do some intricate masking.
is there a technique or a guide in a mk5 haynes manual
Cheers,
Christian ;)
  • Views 1.6k
Cheers,
Christian ;)
The plastic casing on a mk5 mirror is just clipped on, use a thin flat head screw driver to lever the casing off the mirror body, working around the edges. Careful you don't slip
Edited by Clayton
Cheers,
Christian ;)
The plastic casing on a mk5 mirror is just clipped on, use a thin flat head screw driver to lever the casing off the mirror body, working around the edges. Careful you don't slip :finger:
i tried this but seemed to be having no luck, just gonna mask it up instead now and get it touched up its black anyways but has a stone chip in it so needs flatting back and blowing over again
Cheers for the help tho! 8-)
Christian
Cheers,
Christian ;)
Christian
keep tring mate, it can be done, try pulling the casing as well, i have had them off a few times in the past. :thumbsup:
cheers fella aint going into the shop until next week, so i think i will have a crack ofver the weekend!
Christian
