GT wont turn over!
i was continuously trying to start the gt after fuel starvation i was feeding petrol throo the lines and then it aventually started....
i cut it off and tried again and nothing !
not even a click! the fuel pump continuously primes as i turn the key the 3rd click to start and does so untill i let go.
what is wrong?! Is the started motor fused?!
as i only see two relays i thought one was for ecu and the other for lambda maby I'm wrong!?
  • Views 1.6k
I'd say that sounds like battery death...
but my fuel pump seems to sound healthy normally when its dead it drones...
although this could be a good idea i may need to invest in a new battery as my mate buggered this one.
try and jump start off a mates car to see if you can get it started that way, the battery may just have lost its abilty to hold its charge or something was on that drained it...
if you rule that out then you can work on the ignition, check that your all your ht leads are plugged in, the coil is wired up probably and all your other connections are in place
you definatly got enough fuel in the car?
  • 1 year later...
What did you make out. i ghave a similar problem.
I had this exact proplem coming home from inters, was running up the strip fine, pulled over to get my time and when i went to start it, nothin. but pump was constantly priming like it wasnt getting upto pressure. it bump started dead easy and has been fine since. so not really sure what the problem was
Gremlins.
Little shits aren't they!
