gearbox oil
alright peeps
run into a fews problems since last :( not got
me drive shaft blots worked loose ( mega poo ) but nowts damaged luckly
but whilst having under the car i noticed a droplet of gearbox oil right under the gearchange linkage
is this common or should i be worried ??
  • Views 1.4k
If it's where the gear change mechanism goes in to the gearbox, then yes, it's quite common, or at least this is what I was lead to believe. Just check/ top up the gearbox oil level and you should be ok for now.
coolio
i wiped it clean today
gonna check if its drip drip dripping tomorrow
we'll have to wait and see!!!
will the gearbox loose all life?
will the driveshafts ever be torqued properly?
will the tramp ever move again?
TUNE IN NEXT TIME FOR
TRAMP 2.0
Apparently even new seals leak after a short time. I wouldn't worry about unless it's proper pissing out.
i got me eblows stuck in the grease today
and then had a look at the gbox and it was forming a drip again :(
is there owt i can add to the oil to refresh the seals??
