Spraying
I'm on about spraying the plastic part of my mirrors (i.e. the casing) as they've become a little pitted and could use touching up before Inters...
Have got spray can of LC9Z and laquer from VW themselves, but am unsure if I need to primer the casing first, my initial thought is no as am just putting a new top coat on as it were but wanted to check first to be on the safe side
Edited by jonPDpolo
  • Views 1.3k
Rub them down with somewhere near 800 grit paper to get the shine totally off them, paint the colour of your car and lacquer them. If its a metallic colour, rub down the coat of lacquer with some 1500 grit paper and give it another coat. Repeat till its nice n smooth!
you only need primer if you go all the way through the paint to the plastic underneath
