bike carbs
I've been lookin around and was wondering if i could fit cbr600 carbs onto a 1272cc gt engine. if its possible what
else would i need exept from the carbs and manifold. and what sort of power gains would i be looking at.
will
  • Views 1.5k
They're about as close as you'll get. The bore is the same as the circumference of the inlet gasket, i.e. 36mm. So buy some 40mm tube with a 2mm wall thickness. If you space them apart by 8mm, they match the port spacing too. I've got 2 sets ;) You'll need a source of sparks and a suitable fuel pump.
I'm thinking about getting a manifold made by bogg bros, would i still need to space them apart or would the manifold sort this issue.
also what sort of power increse would i be looking at.
