Mk4 central locking stopped working
the central locking has just stopped working. I've checked the fuses but they all seam fine. what usually causes the central locking to stop working i have heard its a common fault on VWs
any suggestions would be great
Chris
  • Replies 8
  • Views 2.3k
is the pump wet ? thats the main cause... water leaking in thru the back light...
does it make any feeble attempt/noise when you unlock the door Chris?
sounds like its possibly suffered the inevitible water damage thet occurs so many times on mk4's
if it makes a slight noise it sounds like it still maybe rescued...
take out the unit and sit it either in an airing cupboard or on a tea towel on the radiator overnight!
when you upnplug it look for corrosion on the pins on the pump i had this so cleaned them slightly and it began to work again but then heavy rain caused a larger leak of water and resulting in flooding the circuit borad completely!
as a precaution when i replaced it i put the unit in a ziplock bag and made sure i tightened up all the seal on the light cluster and had no problems from then on!
Christian
woyuld explain it actually, its been raining heavily for a few days where abouts is the pump? is it the box behind the first aid kit holder behind the drivers side rear light?
i will take it in bits when i get home joys! :lol:
hmm well I've taken it off and it was a bit damp like, i have left it on the boiler drying out with the lid off it. the pins are reasonably clean, was a bit manky in there tho
hmmmmmm sounds like it has suffered a bit of a water leak, have you changed the rear lights on yo mk4?
just nip up the bolts to check the seal is spot on! 8-)
def recommend sticking it in a ziplock back to prevent any more water damage!
fingers croassed rying it oput will resurrect it! :D
Christian
If you cant fix it, I have a spare :D
cool beans. well I've no changed the back lights. its not very wet in the boot or owt either but there was a good few ML of water inside it
works like a peach. gave the bolts on the back light a nip up aswell. might seal the pump up in a ziplok bag as suggested, got a box full of them
