Help! (need lots of filler)
I've been attempting to smooth the 16v front bumper off...nearly there but just wondering does anyone know wher i can get lots of bumper filler from...a big tub or somthing because buying the 100ml tube Isopon bumper filler by david will leave my pockets empty :-p. It is good but i need lots of it ...or is there any oother one which is as good i could use??
Thank You!
  • Views 1.9k
I use Plastic Padding Elastic filler on bumpers
but is this for metal or plastic bumpers? :S (discription says metal)....
its supposed to be for normal bodywork, but its very adhesive and slightly flexible so unlike normal fillers shouldn't crack out, if the surface is properly keyed.
and that was a standard mk3 bumper
even on my rear bumper it only cracked out where I was crashed into by a bmw, the rest of the filler stayed in place.
thnks optima...I'm assuming the filler on the bumper which was on your car was ther for some time... where could i get some of this filler then??
8-)
car shops or ebay
