bulb after bulb after bulb...
small problem with the brake light on the passenger side of the mk3 sqaure it just keeps blowing bulbs! they are definately blown cos i will put the bulb in a different place and it doesnt work, i am on my 4th bulb now since buying the car and it is the only light i am having trouble with everything else works perfectly, the bulb will usually last about a month or two then it will go, everything looks ok no major damage that i can see...
anyone got any idea what could be causing it?? cos i am getting a wee bit annoyed now with having to keep buying new bulbs
cheers
nath
  • Views 1.8k
Are you using the right wattage bulbs? I blew a brake light bulb in mine just after changing it because it was the wrong power.
well I'm going by the little book in halfords so i guess i am... although i will double check tomorrow
Ah right ok. I can't be of much help then. Sorry.
check it has a good earth, other than that i dont know why it would blow, is it getting damp or anything?
The socket could be fucked and shorting maybe?
i had another look today the bulbs are deffo the right wattage, I'm pretty damn sure its not getting wet but the bulb did seem a bit loose in the socket compared to the others so it may be that...
