toolage
howdy
i wanna buy a couple bits but i don't know what i need to order
first is the bit for the gearbox fill / drain plugs - what size are they
and second the size of the spline key used on the drive shaft bolts
cheers peeps
  • Views 1.5k
the gearbox drain plugs are 17mm hexagons and the driveshaft splines are either 6mm or 8mm, but someone else can confirm that
cheers gezza
daddys going shopping tomorrow
Driveshafts are M8's.
I made a 17mm gearbox tool using a 17mm head bolt with 2 nuts locked onto it. You use a spanner on the nuts with the bolt head in the gearbox plug. Works fine for the amount of times you are likely to have to use it.
best way to get the box plugs out is with a wheel bolt, there is enough head to get them right into the plug and get a open ended spanner round it too.
splines are 8mm
cheers peeps
i think some five finger discounts from work are to be had :)
