2 ohms // 4 ohms
As title says whats the difference between 2 ohms and 4 ohms? The sub i want comes in both for the same price, so which one should i get?
Edited by Tom7
  • Views 1.2k
is is the impedance of the sub, there are different values to allow different wiring to amps...
have a look at your amp and see what its specs are, if the amp does for example:
400wrms @ 4 ohm
600wrms @ 2 ohm
and the sub is 600wrms then pick the 2ohm version
you need to match up the values :-p
nice one cheers ill hav a look
