gt running probz
hi all, bit of a noob, not to cars n mechanical bits n bobs in general, but polos!
posted a thang in general then someone replied to kick me in the butt and move techy stuff in here, so
i have a 91 gt............starts fine, runs a tad lumpy.....when it gets up to temp, sometimes, and only sometimes it loses all power whilst driving 'normally'...doesnt cut out...then everything is fine again, the car was cheap, think mainly due to this prob
drove it 16 miles to work and back today and it probably done it a dozen times max...i dip the clutch, let it do its 'thing' then it runs fine again.........
anything that these super (my opinion) little cars suffer from....any of you guys come across this?
i'm going to go down the first usual route of plugs/cap/rotor arm and leads n see if that cures it.......one suggestion has been the coil pack breaking down......but dont want to go down that road just yet.
i HATE intermittant elecky faults...!!, cheers in advance...tel.
mine was running abit dodgey, not as bad as yours, but generally not too great. idle wasnt smooth etc
just use some carb cleaner then take the car on a nice long motorway run.
I did plugs, leads, carb cleaner, oil etc and just hit 5k for about 10 minutes. Also chucked a few litres of engine flush (fuel additive stuff) for good measure
after that the car ran like a dream
if your adamant that its a leccy fault then also try re-setting the ECU by leaving it disconnected over-night.
Edited by ---Ripley---
cheers fer the response.....i'm going to try all of the above........but as a noob i will just ask? the ecu, where do i unplug it?..also
are you going to the bluewater meet on weds? I'm thinkin i might but i am quite old(36) and was wondering if it'll be all young boyeeezz!...i am young at heart tho....lol
The ECU is located on the right hand side of the engine bay, just underneath the scuttle tray -near to the windscreen.
You can just undo the -ve terminal on the battery and leave that overnight.. but I have a feeling it doesn't always reset and can tend to hold some memory...
cheers to all concerened.....will keep you posted!!
all left to do now is
1 lower,
2 wheels,
3 many many things that will catch my eye on here too!!!
like the bike carb idea/twin 40's route...any probz in doin this, as the fuelling is injected at the mo??
