mk4 polo ariel base?
Anyone know where i can get a mk4 polo ariel base? and how much it will cost roughly....
  • Views 1.5k
VAG parts sell them and they're not too pricey.
about 15quid i think, bit fiddly to replace as the headlinign needs to be unclipped!
i think there is a guide on UK-polos! IIRC
Chrispy is right i think i remember seein a guide on uk-polos. I bet GSF car parts sell em too.
or get one from the scrap yard
not difficult to replace at all, the piece of plastic holding on the head lining just unclips
but make sure you get the right one, the earlier mk4 ones are different to the later ones
the later ones has a built in amp and requires a 12v feed
I only want one cause mines turned grey and the little rubber ring around the bottom has a split in it
in which case, vag part it is then, they sell the rubber replacement bit
