overheating problems
right here goes 97 seat ibiza 1.4(same as polo) mpi engine, runs perfect and can be driven anywhere for as long as you like until i stop and leave it for say half an hour start it drive of and within a few minutes it boils, had new thermostat fitted as this was suspect but still has problem, runs fine with thermostat removed and doesnt overheat,
any ideas would be greatly apreciated and fast as its mums car,
cheers david
  • Views 1.4k
surely someone knows something?
You run it through vagcom?
Simon
no idea what that is or how its done,
Could be the water pump, or the seal in the coolant tank top
Vagcom is basically software used to test VAG cars that have OBD capability, it can read fault codes and the like. It costs alot but the older versions are available free and you can get a cheapo cable off eebay which does the job, failing that find some one near you with it and borrow it.
SImon
