Gt bottom end on an MH
Just a final check before i waste some money...
Will the GT block fit straight up onto an MH head... and everything else will go straight on aswell? Has anyone done it?
Rich
  • Replies 10
  • Views 1.9k
????????????????? nobody?
cant believe nobodys doen this?
but why?????
High compression MH?
edit: Actually, yeah, why? What's up with the GT head?
Edited by tobyk
my bottom end is fucked, it's higher compression and it's a bottom end that isn't fucked :D so does that mean it'll bolt up nicely?
also, i say its an MH....
Originally a carb'd model ('90) with a round air filter...
the GT head and MH head will match up, no problem.
cool, so the GT bottom end will match up! :D
Will the oil pump fit off my MH, and sump etc?
everything is the same apart from the pistons, so yes. But sounds like this gt engine is knackered? :lol: Why are you changing the oil pump?
Lol, i hope it's not knackered! :lol:
Just wandering whats interchangable off my current bottom end, as i'm swapping it from the standard MH. Are the pumps/sump etc the same...?
Oh yeah, you also mentioned the water connection or somthing? Will i need that?
