GT exhausts?
first of all is the gt hatchback backbox different to the coupe or will it fit ok
also thinking of doing away with the backbox and just have a staight pipe or side exit.will it pass a mot with no backbox and will the gt run ok without one or could it cause problems?
  • Views 1.2k
if i remember right, the coupe backbox is shorter than the squares.. so it sits under the car.. some say this is good, others say is bad...
I'm sure someone will correct me if I'm wrong!!
no comment on side exit as i haven't a clue about them!
I have a coupe tail section on my square and it tucks away nicely, definately shorter than the original. So I'd say yes a hatchback exhaust will fit your coupe, but stick out a fair bit.
i assumed you had a square / hatch and wanted to know if a coupe one would fit, ... not the other way round! sorry
yeah,i have a coupe
