Internal Ariel?
Hey there...
right I'm going to be blanking off my arial on my mk3 coupe....but what do i use instead? is there some kind of internal ariel that i can hide away somewhere? or will I have to get one that sticks to the window?
  • Views 1.6k
bump
seen an ariel laid across the scuttle cover before on a mk 1 golf and zip clipped down you need to earth the body of the ariel to get it to work any good
Rob
You can get them on ebay - go to item number 160129135397
They look like this:-
Cheers :thumbsup:
They're rubbish,my old dear had one in the top of her windscreen and it played havoc with the rds. The rear heating element of my Fords have worked well enough to use,id adopt that method if i wanted to omit the external aerial.
