Lets Play a game.....
Which of the above wires do I attatch to the other wires to make my headunit work?? All help most appreciated because I'm sick of humming, I can't sing and I have a weak whistle.
  • Replies 9
  • Views 1.9k
Red/yellow are power
black is earth
and the ones with a colour and black stripe are speakers
So
Red-Red
Black-????
Browns-???
Blue and white stripy -the coloured and stripy ones?
Colours I have.
Car Loom From the right hand side
Brown/White
Red
From the left
Brown
Brown/Blue
Blue/Grey
Blue/White
Blue
Red
On the wiring block I have (starting from top left working across to top right then to bottom left across to bottom right)
White
Green
Purple
Grey
Blue
Red
Black
White/Black (come on the toon!!)
Green/black
Purple/black
Grey/Black
light blue
Orange/white
a empty one
yellow.
Help me peeps what needs to be connected to what?
Brown/White
Red
From the left
Brown
Brown/Blue
Blue/Grey
Blue/White
Blue
Red
On the wiring block
White
Green
Purple Phone mute
Grey
Blue Amp switch
Red 12v+
Black ground
White/Black speaker
Green/black speaker
Purple/black speaker
Grey/Black speaker
light blue
Orange/white Illumination
a empty one
yellow. Switched 12v
stereo connector
green/green black = rear speaker o/p
purple/purple black = rear speaker o/p
white/white black = front speaker o/p
grey/ grey black = front speaker o/p cant remember which hand side they are
red = ignition fed +12v
yellow = continuous +12v
blue and the blue/white wires= 12v o/p for connecting remote amp wire or powered ariel
dont worry bout the other wires on the block coz you wont need them, just cap them off
car loom
red = 12v continuous
brown = negative earth
blue wires (on the left) = not sure which one but one will be and ignition fed 12v
best thing to do is check this with a multi meter (if you dont and you blow your stereo dont come crying to me!)
loon on the right
blue/blue brown = front speaker
red/ red brown = other front speaker
easiest way to check will be to pop a speaker out and see which colours go to which side
you will have to run in new wires for rear speakers if you are fitting them.
if this doesnt make any sense now, then i would advise you not to wire in your car stereo! get a mate who knows to do it!!
stereo connector
car loom
loon on the right
Ahh thank you *the mist of wiring confusion clears* I now know what to do!! Can't wait to have some music in the car!!
stereo connector
car loom
loon on the right
I cant remember off the top of my head, but I don't think that there is an ignition supply on the 86c. I had to splice into another wire.
Also, again I may be wrong, but I seem to remember that the +12v wasn't the red wire. Best to double check this before fitting the unit
and buy a multi meter too! better safe than sorry! a friend of mine managed to set his 106 on fire due to messing up the install of a radio. lucky the car was a shity pug
I'm just gunna lick the wires :-D
