Door Speakers
both the speakers in my drivers door have stopped Woking, its not the balance and every other speaker works. any ideas?
  • Views 1.7k
Remove the doorcard and check the connections on the speaker a cable could of broken. Or if they are still the OEM speakers i would suggest changing them. You should be looking for 16.5 cm speakers to fit the door pods.
IIRC, the door has a seperate tweeter/mid. If so, its unlikely that both would stop working at the same time.
This could eb one of several issues.
1-headunit internal amp faulty. Test by swapping the channels in the back of the unit.
2-Wiring fault, either at the unit rear, or on the loom, through the door to the speaker.
3-As has been said, faulty speakers
