Induction Kit for a Polo AFM mk3 NZ
I know you can put a golf mk2 AFM on and bolt a cone filter to it, but can you bolt a cone filter onto an AFM on a NZ polo???
  • Replies 8
  • Views 1.7k
anyone?
yep
a pipercross induction filter/kit will bolt onto the polo nz afm as it is the same item as the gt afm.
however, i'd recommend a k+n/pipercross/jetex replacement high flow panel filter and a decent cold air feed, i have drilled my airbox and made a bit of a heat shield and yeah, it seems to rev more freely
but i use a golf afm on my nz polo, i have modified the airbox so the golf item mates upto it so i can use my k+n panel filter. acceleration is improved wih the golf afm.
i may be selling my golf afm soon when i sell my car, and it's set up for my nz engine ;)
cheers people, i have already got a k and n panel filter on it but not drilled the box or anything. Where coudl i get a gt induction kit from then?? and what would i do with all the other pipes that go into at the front and what about the carcoal canister as well??
also when would likey to be selling the golf afm martinb???
need an answer only 1 hour left!!!
Yes, as the NZ has the same AFM as the GT.
gdgd, cheers fella
