6n2 broken locks
my drivers side lock never worked, so i always lock via passengers side (meant to get it fixed but never got round to it...) but now that one is gone too.
basically i locked it earlier and the key stuck in the lock, it wouldnt turn back to vertical to get the key out but with a bit of force i got it out. now it wont lock either so i cant lock the car at all unfortunately. help!
anyone know about this? as far as I'm aware its a common problem? any links to other threads would be appeciated too thanks.
cheers, Lisa.
  • Views 1.4k
Hi Lisa,
What most likely has happened is a couple of bits inside the lock have sanpped - not the acutal barrel where you put the key in. Take the door handle off and dismantle the lock. Have a good look at a picture I posted earlier (see below) and you can acutally see which bits have snapped.
http://www.clubpolo.co.uk/forum/index.php?showtopic=68525
http://www.clubpolo.co.uk/forum/index.php?showtopic=65822
If you need some pointers on this, let me know!
Kind regards,
PoloD.
  • 4 months later...
Hi Lisa,
Kind regards,
PoloD.
these links are not working, could you repost the info on how to fix the problem?
I have seen your post at
http://www.clubpolo.co.uk/forum/index.php?...083&hl=lock
but a bit more info would be appreciated
Syd
