gearbox box seals
hello
does anyone know how to change the seal for the gear selector rod on a 8p 5 speed box ??
  • Views 1.2k
8p thats mk3 right? If so then you need to mark the position of the selector on the shaft 1st. Disconnect the selector & slide rearwards. Clean the gunk off the shaft. Hook the old seal out with a sharp screwdriver. Not much oil will drip out. Slide on the new seal. IMPORTANT, must get the selector on in the exact position it came off. The bolt usually leaves a mark on the shaft. Job done.
cheers red
me car is a mk2 running a 2g engine with the 8p box.
so all i got todo throw it into 1st gear, mark out the selectors position
disconnected it, and just prise out the seal
is it easy to put the new seal in ?
Yep it should just slide over the shaft. Shaft needs to be clean though or you will shove muck into your box. Not a long job its just getting the selector back in the original spot.
cool
thanks again red
