91 polo gt fuel filter
hi, i justed wanted to find out how I can replace the fuel filter in my gt.
Do I have to empty the fuel tank?
What is the correct procedure?
thanks
  • Views 1.9k
If its the same as other mk3 the filter is under the rear of the car. £5 from gsf. Need to clamp the hoses either side of the filter after depressurising the fuel system. May need new clamps as some are crimped on & not reusable. You need to clamp the hoses with rounded clamps. You can use mole grips with sockets on the ends to do this.
how do i depressurise the fuel system,
i have been told to disconnect the fuel pump relay harness and then the engine will die and then it will be depressurised
Where about is this
Iv taken a few images of the area around the fuse box, can somebody please spot out the fuel pump relay
fuse box
fuse box 2
fuse box 3
3
Its the lower square relay to the left of the ECU
