Power cable gromet?
Where abouts is it? do you have to take out the glove box or is it just behind the carpet on the passengers floor? Not had the glove box out to check yet, just pulled back the carpet and saw what looked like a nut under there, but wasn't sure if that was it?
Cheers, Rob. :)
  • Views 1.2k
it makes it alot easier if you take the glove box out! i have an airbag where the glovebox usually is so it caused me a bit of hassle..
nice one pal, thought id have to take it out, mine hasnt got a passengers airbag so should be too much of a problem to drag out. Am i right with the grommet i found though? the one with a silvery thing going through it? or is it higher up?
the one i used was quite high up and already had a taped up bunch of cables running through it so i just poked the power through beside that little group!
nice one ill have a proper look and probably use that one, what size cable you got through it? i need some 4Awg through there.
