6n replaced AEX engine now wont start
Hi all
I have just replaced the AEX engine in a 1997/1998 6n Polo with another second hand AEX engine (because the original threw a rod and burst a hole in the side of the block at about 98000 miles).
This involved removing the battery (which had gone completely flat while sitting around waiting for me to do the repair), charging the battery out of the car, removing engine and gearbox, transferring intake manifold and injector rail, distributor, throttle body, alternator, putting in new clutch, oil, antifreeze etc etc to the secondhand engine then refitting to the car, taking care to connect everything back up to the way it should be.
I then connected the battery and tried to start the car.
(LEDs below the speedo are flashing Service INSP).
Engine turns over on the starter but doesn't fire.
I have run VAG-COM and can see a couple of minor faults (533, 524 and 1087)
According to
www.airbagnews.com/PDF/Fehlercodes%20VAG%20english.pdf
01087 means Basic Setting Not Performed
(I suspect that this is stopping the engine from starting).
ross-tech talks about doing a throttle body alignment at http://www.ross-tech.com/vag-com/cars/throttlebody.html
but when I try this, I find out that I cannot follow the steps (because I have not registered/paid ross-tech).
I really dont want to pay ross-tech 99 dollars for something that will probably only use once in my life (I hope)!
(I have tried disconnecting the battery for a while, then reconnecting and leaving with Ignition on for 5 minutes, but that doesn't change anything).
How do I overcome this and get back on the road?
Many thanks,
Steve
  • Views 1.4k
have you checked for a spark and fuel pressure? How easily does the engine turn on the starter, is the battery holding enough charge to turn the engine quick enough to start?
Hi hayesey
Thanks for asking. The battery is turning the engine over plenty fast enough.
I haven't checked for spark or fuel pressure yet, I am on my own at the moment, so I will have to wait for someone else to turn the key while I look for a spark. Checking for spark won't be too hard, but how can I easily test the fuel pressure? (The car has multi point injection).
I have been assuming that it is control unit/engine management problem. Is resolving the 1087 error not absolutely essential?
Thanks,
Steve
Hi all,
OK I looked into the spark situation and noticed that I hadn't connected the LT lead to the distributor. The empty socket was right in front of me the whole time, but I was looking everywhere else.
Doh!
Once that was connected, the engine started right up.
Over the next few days, I'll use VAG-COM to investigate
01087 Basic Setting Not Performed
and see if that error has gone away.
That would make sense to me because a connection to the distributor is fairly basic.
Thanks anyway,
Steve
