Oil Pump Removal / Refitting...
I am thinking while my sump is being changed i may aswell use a new oil pump and chain....
Is it going to be beneficial and easy enough to change? I will be working from underneath the car so don't wanna be messing about too much...
Also is there anything I can fit incorrectly or mess up that would knacker the engine?
Many Thanks
Dave
  • Views 986
You'll have to remove the cambelt lower pulley to fit the chain. It's easy enough to pull the pump off though.
As Yeha said - but there's no need. You can check it in situ with a feeler gauge for wear,and more importantly,you can tension the chain. You dont need to remove the belt for these. Then simply scrape any crap from the pick-up gauze. As long as those three are okay,changing the pump is pretty pointless.
