Misfire at around 2000rpm on Polo GT
right then........the mis-fire was only slight when the car was rolling roaded with the following spec......
1.4 ABD / GT conversion
GT Cam
Poloace chip
Ashley 4-Branch
Stainless Exhaust
Golf AFM
K&N Panel filter
Halfords Dizzy Cap and Rotor arm
Correct Dizzy
Standard Coil
VAG Leads
the mis-fire is really noticeable now since fitting........
268 Schrick cam
chip from Hardhitter
i'm sure the recent mod's have'nt caused the problem.........but they have "amplified" the mis-fire
at around 30mph in 4th or 5th gear the cars pulling around 2000rpm or less and its really juddery :angry:
Any idea's ??????
  • Views 1.6k
halfords dizzy cap? shame on you! :-p It had a new beru one on there a couple of years back. Anyway, seeing as it's at 2000rpm i'm thinking possibly too advanced. What fuel are you running it on?
I'd go back to basics, fit a known good dizzy; stock GT AFM; check cam timing (as per Schrick) and ignition timing (stock). Make sure you redo the ignition timing after timing up the cam. How healthy is the fuel system? Were the Halfords ignition bits the same as the OEM ones?
Halfords Dizzy Cap and Rotor arm i had that problem till i went to vw and got one
