6n2 rear lights on 6n
Can any one tell me how easy it is to fit the tail lights from a 6n2 onto a 6n.Is it literally just remove originals and bolt new ones on.All the bulbs will be rite and that?
  • Views 1.9k
pretty much. i did this on my 6n yesterday. the bulbs will be the same and the new light units will bolt straight on (may want to trim the edges with a file slightly) using the same nuts. you will need to swap 2 of the wires on each side around but it is very straightforward.
there is a how to guide here mate!
http://www.tigerstyle.co.uk/poloforum/viewtopic.php?t=9117
tells you in detail exactly wht you need to do to fit them
Christian ;)
Cheers mate.Any ideas were I can get em from.I'm presuming VAG parts are pretty expensive orare they the only place you can get from
scrappies mate, dont let them over charge you i paid 30notes for mine one place i went to wanted 45 a side i told him to fuk off! :lol:
that was a vw dimantlers, so i think they just like to charge what they want! :roll:
i followed this guide and they still stick out do i need to file/sand all inside edges to get them to sit flush or is it that one of the holes isn't big enough ??? they only dont sit flush on the boot side and the middle holes have been enlarged to over 15mm !?!?
i got a set off ebay for £25 delivered. Make sure that the clusters include the bulb holders aswell tho!
