correct oil filter?
my 1.3spi mk3 is due an oil change so I've just bought 5 litres of Mobil's finest and a champion oil filter. The little book in halfords said 'C161' so that's what I got. Looking in the engine bay though, my oil filter looks different. it looks as though there's a big fat bolt through the middle of it. The champion one has no big bolty thing in it. Can someone confirm that C161 is correct for my polo please?
  • Views 1.4k
Usually cheap filters don't have the nut on the end where as the genuine one or better quality ones usually have a nut on the end.
Or so it was with my Jetta anyway...!
Yeah the better ones are a smaller canister with a nut on the end which is useful when they are tight.
I was hoping that was the case. It'll only be changed again in a few thousand miles again anyway. cheers :)
The Haynes isn't very clear on this. They say that AAV from 07/92 is C161, but don't specify what should be fitted to earlier ones. In any case, god only knows why there are 3 different filter types for the MK3, when they all require the same (genuine or OEM) filter regardless of cc and age.
As has been pointed out, OEM ones have a removal 'nut' welded to the end, whereas others don't.
fuck it, its an oil filter
i say as long as it fits, stick it in there
as far as i can remember MK2's use the 056115561G and MK3's use the 030115561AB but either will be ok for both MK's
I like your way of thinking. This is entirely the attitude I like to take with my car... I must never let myself get a 'good' or complicated one...
cheers guys
