Oh Jesus! I can't get the timing belt off!!!!!!!!!!
Is it me, or is there insufficient room to get the auxilliary drivebelt wheel off between the crankshaft bolt and the bulkhead? This is doing my nut in. I can't get that piece of plastic shite (lower timing belt cover to you) off and therefore I can't get the timing belt off. For f**k's sake. Somebody shoot me - please!!!!!!!
(it's a mk3 coupe 1.05L)
Edited by Chuck Yoghurt
  • Replies 12
  • Views 2k
you need to drop the engine down a bit
i did it by putting my jack under the sump (on a block of wood)
undo the driver side mount and slide it out, then dropping the engine down (resting on the jack)
You're an angel, sir.
So if I undo the bolt going through the rubber thing, slide the rubber out and let the mount rest directly on the bulkhead, this will give me enough clearance?
i think you mean the inner wing not the bulkhead
you dont even need to rest it on the inner wing, i remember i only have to lower the mount a little more, try it a see
You're so right!!!!
Only have stupid scissor jack i'll let you know if the engine falls on my head.
Thanks again, mate!
I got a crowbar in between the block and inner arch. Put a towel between the bar though, I managed to remove a fair chunk of paint.
Unless anyone knows of a reason why you shouldn't lever the engine that way?
yeah I'm with loosening the engine mounts and levering the engine over, rather than lowering it
FluxCo, you're a fucking dancer, mate.
Thank. You. Very. Much.
This is how garages have done mine in the past. Can't see any real reason why not, although the inner wing is both badly dented and scratched where the have levered it.
Glad to hear it appears to be sorted :thumbsup:
done mine recently,dont drop the engine.
just undo the bolts that are on the mount to body on cam belt side and lever with big pole.
to replace pulley,balance pulley on the shaft and lever engine mount again if you do it slowly it should drop back on
make sure it's the right way round first though !!
Thats how I done mine :lol:
I think i removed the bolt in the middle.
different strokes for different folks
there are always different ways of doing the same thing, not a case of DONT do it
