mk4 polo geaboxes
hi there, i have a 1996 polo1.6cl, geabox is shagged and I'm having trouble finding one from a 1600, anyone no if a 1.4 mk4 or an ibiza box will do, mine has manual adjust clutch cable, and 1 rod and 1 cable for shifting, any help would be great as needed on road asap.
thanks
david
  • Replies 11
  • Views 1.8k
have you priced up how much yours is going to cost to be repaired? just as another option incase you cant find s/hand
s/hand stuff is ok but you never really know what your gonna get
sorry I'm not sure on the answer to your question all i could say is maybe :lol:
i need the car running by sunday/monday so second hand is the only option, does anyone no the answer??
cheers for you help though ade
They do seem to be in short supply. :sad:
I was quoted £250-£300 to get mine rebuilt! :shock:
At the end of the day, its going to have some sort of guarantee on it when its done, theres no telling how long a secondhand one is going to last is there?
Are there any checks you can do on a secondhand unit?
£250-300 for a gearbox rebuild seems pretty cheap.
Not what you know.......
Sorry didn't understand that?
...who you know
mine was 600 complete rebuild and new clutch... and they collected and dropped off my car 8-)
Wouldn't have thought other boxes would go in easily... Rebuild.. only takes a day or two
Edited by polo_phil
AH yes of course :lol:
what you mean by shagged {noisy} or totaly jamed up if its just noisy bearings get it rebult if you want to keep the car a while put secondhand in if not planning to keep it long.
if its jamed up the bearing has probably come apart and minced gears so probably not worth a rebuild as too expensive to replace gears.
there should be a sticker in the boot with paint code gearbox code ect on it{wasnt on mine} or it will be in your service manual failing both these phone your local vag dealer as i did and get your code then phone breakers with your code they can match to what they have 1.0 1.4 ect you may get lucky and find that others will fit.
cheers rally nav, just what i needed to no, got a replacement gearbox for £80 from a scrappy fitted yesterday and car drives like a dream sooo much better than before,
thanks for all the replies and info.
david
