re-badge
just orderd black rear and front vw badges for my 6n2...how easy is it to put the badges on?
i've debadged the polo badge by slicing it of using dental floss (worked a treat just use hot soapy water to removed remainding glue) do i use the same system to remove the rear badge or is it screwed in? and i presume the grill badge will just need some sort of leavering out, can anyone help me? pics or a website would be nice. Cheers
the rear badghe is just gloed o yer and the front badge youll need to get the grill of with the ikle popper things that it tells you to do oin the haynes manuel... and just pop it out!
simple just needs a bit of brute force with the front as it can be tight
Cheers mate i'll give that a go had no trouble with the other badges...any tips on how to line up the new badge so that it sits on staright?
