Polo 1.9 NA Diesel Somking before 2200RPM, then runs perfect
Have a 1.9D Polo 1997, it pulls really well drives great, but has a problem that it seems to be like pinking from about 1800 to 2200 RPM and leaves a trail of smoke behind it, everywhere else it runs great and very little smoke (well apart from when it hits the governor). Its black smoke (un-burnt fuel and it smells strongly of diesel)
I changed the injectors thinking it was them made no difference at all. Tried my old injectors in another car and they ran perfectly.....
I moved the thing on top of the throttle linkage with 4 wires going to it. This makes the smoke much less (and moves it up the RPM a little 1900 to 2200) but doesn't cure the problem.
Any ideas what I can do to sort the problem? Filled it up and added some redex, to make sure there is nothing sticking, but only done about 20 miles so wont have made any difference yet.
Stu
  • Views 766
Popular Days
anyone???
Changing the pump over made no difference at all. I reset the timing again and it seemed to make it a little better (less smoke) but still the same problem at the same revs.... well it my have moved up from 1800 to about 1900 before it starts doing it, but that could just be my imagination after spending days trying to fix it.
