Speedo stopped working on 6n2!
hi guys
the speedo on my mates 6n2 has stopped working for some reason.
I've plugged vag com into it and it has no faults with speedo. speedo unit is fine.
what else could it be?
i know the car was involved in an accident, which caused some damage to passenger side front wheel setup.
the abs sensor was missing and the cable was cut!
I've since then replced all of this, but still nothing...!
any help much appriciated!
mitch
  • Views 1.2k
Checked all your fuses???
luke
Same thing happened mine, jus get a new sender in the gear box. Acutally check the 3 connections on the top of the sender first one might be loose.
