Smooth Boot
i have a fully smoothed boot for my polo, going to put number plate on rear bumber but i dont know how to light it up
any suggestions
cheers
  • Views 1.6k
only thing i can think of is running a wire from your back lights, so when your tail lights are on (not brake light) the light you use for the plate will be on. chav alternative is mount a neon which'll have to be not visible above the number plate and have it plugged into cigarette lighter on a switch.
bit of a pain to remember to switch it on.
i'd say run a light from your tail lights.
luke
can you not reroute the original wiring?
True!!!
there must be an original wire which was used to have a light in the first place!!!
I was thinking outside the box to much.
luke
True!!!
luke
yep. if you can trace that through the boot door jobby then it would be a piece of piss to either pull that out and reroute to the bumper or just cut it off and splice a new piece into the original wiring and send that to the bumper. it aint rocket science :D
create a slight recess then spin the original lights upside down,so ther now in you are recess. then just smooth over ther old lighting holes.
True!!!
luke
just read that back.. sorry for sounding patronising, I was absolutely hammered at the time
