IS IT A WRITE OFF? can it be fixed
Dudes whats the worst damage on a polo front end that canbe fixed? basically all thats happend with mine is the front inner wing has been bent in about 5cm and the front ripped off where the bumper mount is. is it repairable? chassis legs look ok? really want to fix the coupe!!!!!!!!!!!!!!!
  • Views 1.3k
Chassis legs would be my biggest worry. If they are okay most of the other panels on the front are bolt on/off. Just check the suspension struts, arb and arb mounts incase its sheared any of those bad boys off.
cheers buddy, well they seem ok, just the drivers strut housing looks as if its moved in a tad...no craking just u can see the paint around the seem sealer has stressed, an where the battery is the metal where the rubber fits has distored a little. any idea? will try an get some pics up, cheers tom
