Mk4 6n2 sat nav unit
Hi all,
Anyone know where I can get a sat nav unit for a mk4 6n2 gti, blue illumination to match the dash, I have found Green illuminated units on Ebay but not blue, any idea of part numbers I should be looking for.
Ricky
  • Views 2.4k
Are you after OE sat nav system? Or aftermarket one?
OE sat nav unit to replace radio and storage hole.
Ricky
Hopefully you get a chance to see this before it finshes
Linky
I don't think VW did a Sat nav unit that lit up blue, but just like the standard HU this one has the red buttons. The Polo has an ISO socket, I doubt you'll be able to get a new one from a mk5 golf/passat as they use "Quadlock" System. This should fit, double check with the seller. Hope that helps
If you can track down one from a mk4 Golf...Would be perfect.
Edited by dipsy_d
think u mean mk5 mate
Ok so lets get this one correct before I spend a few hundred notes, the part number on Ebay was VW MFD D 3B0 035 191 B, can anyone confirm this as the absolute correct part number, if not I will check with my local dealer.
Ricky
Don't Think many people have the OE sat nav installed, you can get double din units that aren't OE that look pretty good, with a hell of a lot more features.
Oh right.....must admit I haven't really looked but wanted something that would look right so thought OE would be best, any suggestions??????
Ricky
