dent in sill, can it be pulled?
seen a car i like and theres a dent in the sill around 4 inches long, just wondering if dents in sills are easily removable?
  • Views 2k
if youve got the right equipment no problem. a pin puller is what you need
when of them where they weld a pin on and pull using a tool? i wouldnt be doing it though, just seeing if a body shop could do it
yeah the weld like a stick onto the bit that needs pulling, pull it out then tidy it up!
