Mk3GT loom into a Mk2 Breadvan
right well i'm picking a GT engine up next weekend and i'm just wondering what problems i'm going to have when it comes to joining the MK3 loom to my Mk2 one.
is it easy enough or is it a Tw*t of a job.
quite good with electrics so technically speak is ok :)
many thanks
Will
a mate of mine did a similar conversion, but on a low spec mk3, he didnt have to touch the interior electrics, so i dont think you will have to other than maybe the clocks. you wont have much wiring in the front of your mk2 so that should just be a case of installing the loom!good luck should be a nippy motor when your done
cheers guys thats helped a lot and also put my mind at rest a bit lol
was getting scared that it was going to be a idiot :p
will do a full conversion update with pics as i go to add to the walk through (Cheers TomW)
cheers once again,
Will
