Is a 13X7 with a offset of -7 ok on a G40?
Is a 13X7 with a offset of -7 ok on a G40? Seen some wheels that I wanna get but dunno if they will stick out the arches too much to make them illegal.
cheers
Matt
  • Replies 18
  • Views 3.9k
That'll stick out a mile on standard arches.
think Neale had some on his mk2 Loon in that size, and were completely illegal.
Being realistic what we talking an inch? or 2
Lots. I now have neales loon and tried 13 x 7 mattigs with an offset of +8 on the front and they sat out about an inch and a quarter.
hhhmm maybe I won't be getting them after all.
The rears with a good streched tyre (Not a pirelli 175/50) would be borderline (ie legal, but rubbing on the arches loaded up).
It seems such a shame to limit the driveability of a car for aesthetics. The sound of rubber ripping every time you pull a few gees through a corner aint (IMO) worth the extra bling factor.
Around an ET 15-20 front would be good.
They'd stick out just over 2.5 inches (64mm) wider than a standard GT wheel.
I've got 13 x 8's with an offset of -10 on the front and 13 x 9 with -10 offset on the back
The fronts stuck out a couple of inches from the arches but they didnt clear my 280mm brakes, so i have had to space them out, now look at the front wheels!!!
Even with berg cup arches on
(9's on the back)
And yes before any smart arsed comments i know the front wheels are on the wrong side!
I may have to swap the 9's on to the front as they actually stick out less than the 8's do with the spacers.
The 9's clear the brakes basically straight away.
Chris
Oh yeah thats probably about 4 inches sticking out on the front
Oops.lol
yeh i struggled
i have 7x13" mini lites with a -7 offset and they stuck out 2" from the arch. i ended up making custom wide arches to cover them. i wanted them a bit smoother than berg cup arches
just buy some wellers mate, 13x8 offset -10, and they werent too bad on the back, and then get 7s up front
GOOD GOD! That's some fucking stretch on those 9s :|
IMHO - perfection is a 7x13 et 15 with a 175/50 up front
and 8x13 et5 at the back possibly.. or even a 7!
Yeah i didnt want to wait 6 weeks to get 215/45 as there were none in the country basically!!
Pheonix i cant decide whether to get the arches smoothed in or have them race with visible screws. Its going to be make or break with the car, as there is a lot of smoothed stuff on the car so them being smoothed would look good.
Ill have to see!!
Chris
Ill have to see!!
Chris
Thanks for the replies btw. But I have just found out that the Starmag alloys I want are a +6 offset, dunno where the f@~k I got - 7 from. Would I get away with a +6 offset on a 13X7 on my G?
They will stick out a little bit, probably about and inch, but yeah should be fine!
I do like the starmags, more of a ford/ mini kind of wheel but i like them.
Hope it all goes well mate!!
Chris
Hmm.. it won't be legal by any means going by the usual rules id imagine.
but you should JUST get away with it.
I'll be 7x13 et10 up front.. and thats more than enough sticky outyness for me! (mk3 gt)
13x7 et-7 is minilite offset.. size.. maybe you got it from there?!
Edited by Mariojoshi
This may sound a bit stupid but my current P Slot Alloys have a offset of 14X6 ET38 and the wheels I want are 13X7 ET6. So does that mean that the new wheels will stick out 32mm more?
Close, you forget that the new wheels are 7 inches wider and not 6inches like the old ones. Therefore it will be 32mm plus half of 25mm, so will stick out 44.5mm more than your old wheels
Chris
Typically,its all about how much the wheels stick out the arches. I'm always more interested in the inside. Id be having any wide rims nice and close to the suspension to keep the bearings as near the centre as possible,and enable me to drive in a straight line. That post earlier,where i said the wheels would stick out 2.5 inches - i forgot to mention that they'd stick out,as in further away from the car,an inch on the inside aswell. That's too far for me. I want to be able to enjoy driving the thing. Id rather the wheel was an inch wider and the offset an inch deeper - same on the outside,but extra expense spared on getting the inside covered.
