Window/Electric Window Help
well, I'll stick this up heere even though it is for the eatpizza I never have any replies on that forum, plus I'm still paying my £5 :lol: and the polo setup is identical!!
I'm having trouble with the passenger side electric window. There are two little black metal peg things in runners that the window sits on (the motor winds both these up and down) However, for some reason or another, the window keeps jumping off the runner thats nearest the door handle.
It was fine for the first couple of months I had it, then someone leant on the window and it knocked it off the peg thing, since then I've put it back in place 3 times and it lasts all of about 8hours before getting knocked off by someone closing a door or something. I have tried putting a cable tie round the end of the peg as a temporary measure but it was very temporary as it slipped off yesterday.
Is there a screw that should or could go into it or something? There doesn't appear to be one on the other side but I don't understand how the window is expected to just sit there without being fixed in any way... or does anyone know why it could keep falling off? There doesn't appear to be any crash damage to the door and its in perfect shape. The window mechanism seems to be fine as well
Any help would be great!!!
I can probably draw a crappy diagram if people don't understand what I'm talking about!
Edited by Mark
  • Views 1.5k
this is a well common prob on the mk4 polo, the clips are a cheapo plastic that falls to bits! you can get replacement clips, but i just used some random self tapping screws, cant remember exactly how i did it cos space is a bit tight, but I'm fairly sure a short handle screwdriver was essential! the window hasnt fallen off again since doin it ove 2 years ago!
this happens to mine all the time! have plans to take the mechanism out and put a pin through it so it will not come off. definately poor design.
is this applied to the mk4? i think i have the exact same problem.
where can i get the replacement clips? can it be done with ease? is the area accessible to put new clips on? HELPPP me tooo
applies to the mk4 aswell suby!
where you been hiding????? 8-)
go to vw, the plastic clips are a couple quid.......
had to replace mine when some idiot broke my window on the old polo!
mitch
mitch your a legenddd...
I've been here... not been in the polo as much... but I've been driving it lately and the window decided to piss me off...
how do you know if the clips are causing the problem?
it goes down crap and goes up even crapper. i tdoesnt get to the top, the motor knows something is up and gives up. is it DEFO clips and NOT motor?
whats the symptoms of runner problems? and symptoms of clip problems? easy to replace mate?
had the same with my drivers side window.. may just need 2 silicone spray the rubbers as get hard.. worked 4 me.
